| Posted: Dec 10 2004 at 2:10pm | IP Logged
Engineer is correct as far as I know. You have the auto switch, you would need the sensor which is part of the defroster vent and ....??? Assuming the wiring harness had a companion connector in your truck.. you still have to go through the Body Control Module (BCM) and if it's not programmed to accept the signal - nothing happens-or maybe something bad.
It's almost the same issue with daytime running lights - Canadian Titans have it - US Titans don't. No one knows if you can program the BCM to get DTR or if there are Canada & US version BCM's
Another mystery of life
__________________ Silver KC LE 4x4,BT,side air bags, Nissan XM,Truxedo low pro
