Subject Topic: Gas overflow Post ReplyPost New Topic
soldierangel
Posted: Dec 13 2004 at 2:13pm | IP Logged Quote soldierangel
Well I've done a search to see if anyone else has had a similar problem, but found nothing.  When I fill up the tank, if I fill too fast, the gas will overflow from the tank.  Not because it is full, but it is getting stopped up somehow from being filled too fast.  This happens nearly everytime.  How would I correct this problem, or is this just something I need to deal with?
Thanks in advance.
Back to Top View soldierangel's Profile Search for other posts by soldierangel
koncept
Posted: Dec 13 2004 at 2:46pm | IP Logged Quote koncept
well mine stops its just that i try to get it to the nearest dollar and sometimes it ends up in my finding gass running out
Back to Top View koncept's Profile Search for other posts by koncept
Mitch
Posted: Dec 13 2004 at 4:52pm | IP Logged Quote Mitch
I've never had this problem. Maybe the pump is pumping to fast, put the nozzel handle latch down a notch and see what happens.
Mitch
Back to Top View Mitch's Profile Search for other posts by Mitch Visit Mitch's Homepage
BMWTitanMan
Posted: Dec 13 2004 at 5:32pm | IP Logged Quote BMWTitanMan
my dealer thinks im insane i showed them on my truck where the gas ran down and cleand the dust off my truck and they still did not believe me--ithey can never duplicate it i can atleast once a week.--3rd repair attempt on the gas over flowing--ok there in no WRON(to far in to far out) way to pump gas i should not have to adjust a gas pump in the filler neck for a 30.000.00 truck--lemon law truck--getting an '05 love the truck --hate the problems
Back to Top View BMWTitanMan's Profile Search for other posts by BMWTitanMan
camino70
Posted: Dec 13 2004 at 6:07pm | IP Logged Quote camino70
I had a loaner before they delivered my truck and every single time this truck overflowed, the dealer tried to blame it on the gas pump.  But it happened at five different stations, all of which I have used with previous vehicles.
So far I haven't had it happen on my truck, I let it sit for a few moments and then fill on the slowest possible selection.
Ron
'04 Canteen LE 4X4 no packages, no mods, yet...
Back to Top View camino70's Profile Search for other posts by camino70
soldierangel
Posted: Dec 13 2004 at 7:30pm | IP Logged Quote soldierangel
Well this problem was not from topping off the tank, it happened everytime I filled up from the start.  Well I contacted Nissan service department and they said it is a problem with some of the trucks having a kink in the hose and it was an easy fix.  I will be stopping by there tomarrow to get it worked out, and I will update you all how it works.
jmacougar
Posted: Dec 13 2004 at 10:16pm | IP Logged Quote jmacougar
I've had the same problem. TWICE! I didn't think anything of it when it happened because I figured I had the pump in wrong.
Back to Top View jmacougar's Profile Search for other posts by jmacougar
camino70
Posted: Dec 14 2004 at 7:44am | IP Logged Quote camino70
When I had the loaner, I never filled it.  I only put a few dollars in at a time, I thought my truck would be ready for me sooner then it was...
And it happened almost as soon as I started to put gas in it.
Ron
TonyG
Posted: Dec 14 2004 at 9:19am | IP Logged Quote TonyG
I have the same issue. my service rep told me someone in his family had the same issue.
Tony
Back to Top View TonyG's Profile Search for other posts by TonyG
soldierangel
Posted: Dec 14 2004 at 4:11pm | IP Logged Quote soldierangel
Well there was no kink to be found and no ubstruction, he thinks that it has something to do with a problem the 350Zs had in that a regulator will not let enough air out as the tank is filled, causing the gas to get backed up when filled too fast.  He is supose to call me later today to let me know what they are planning on doing.  If it's what he thinks, the part will be overnighted in, and I can have the truck fixed tomarrow.
I also must say that Nissan has got to have the best customer service I have ever seen.  Or maybe it's just here in Oklahoma.
