Subject Topic: 7500 MI SERVICE - had a few things "fixed Post ReplyPost New Topic
Hendo
Posted: Dec 19 2004 at 9:20am | IP Logged Quote Hendo
So I took it in a few days ago to have the once over done.
I complained of brakes shuddering when I brake hard, the drivers window not coming up, a vibration at idle, a very noisy rattle in the front end, and the gas spewing from the tank problem.
OK, 1st off they changed out my rotors, pads and a few other brake parts.  For the window thing, they said they all do that and it is a safety feature of some kind....I guess I can live with that.
For the rattle I had, they found that the entire front bumper assembly was loose as well as the hood latches.  So they had to completely remove and reinstall the front bumper assembly....NO MORE RATTLE  :D
OK, get this...for the vibration I felt at idle, they wrote "checked balance on all 4 tires, found out of balance tires and rebalanced all 4 tires.  HHAHAHA  They must have been pretty far out of balance to cause vibration at idle.
As for the tank not accepting gas problem, they said they could not duplicate it.  I knew I shouldn't have dropped it off with a 1/4 of a tank...only does it on empty.  Anyway a different, more knowledgeable service rep told me that the problem is with the tank and that they will be replacing the tanks, but that they are on super duper back order and it could be months.
Back to Top View Hendo's Profile Search for other posts by Hendo
thepuffman
Posted: Dec 19 2004 at 10:36pm | IP Logged Quote thepuffman
I've heard numerous times that the gas problem is a vent hose needs replacing...also, It isnt really a good idea to run it down below a 1/4 tank....GL...keep on truckin
SE Kingcab Smoke Gray, Big Tow, K&N filter, Silverstar lamps, Peragon hard tonneau, (Sirius SR, 350W Alpine amp, Polk spkrs, 2 RF 8" subs, custom box)
Back to Top View thepuffman's Profile Search for other posts by thepuffman
Hendo
Posted: Dec 20 2004 at 8:41am | IP Logged Quote Hendo
Well, when you drive a lot and fill up 2-3 times a week, filling up with 1/2 to 1/4 tank left is not an option.  That would mean I'd be at the pumps 4-5 times a week.  I'd really rather the truck just perform the way it should.
DirtDobber
U.S. - Florida
Posted: Dec 20 2004 at 9:23am | IP Logged Quote DirtDobber
So far this has not been an issue with my 04. I put a little over 26 gals. in the other day after going 403 miles and had no problems with the filling.
DD
Back to Top View DirtDobber's Profile Search for other posts by DirtDobber
Stubbs
Posted: Dec 21 2004 at 7:56pm | IP Logged Quote Stubbs
Back to Top View Stubbs's Profile Search for other posts by Stubbs
Stubbs
Posted: Dec 21 2004 at 8:00pm | IP Logged Quote Stubbs
oops sorry, kind of double clicked there.....on your windows not going up...that is a TSB for the switch shorting.....waiting for my part to come in...It is fairly a new bulletin, tell your dealer that the part numbers are reversed if they order a switch for a cc they'll get a king and you get the idea.
The bulletin number is 04138 title Auto power up inop. This is NOT a safety feature. You just got smoke up your %$#.
Good luck.
Hendo
Posted: Dec 22 2004 at 9:41am | IP Logged Quote Hendo
thanks
IQ9*
Posted: Dec 22 2004 at 2:43pm | IP Logged Quote IQ9*
I got the same response about safety and went to the passenegers side and asked why on the driver needed safety windows. I was then told they were working on a fix and to be patient. I guess the TSB is out and I have not gotten a call.............
04 LE CC, 4x4, Pearl White, debadged, Venture Clear Bra
Back to Top View IQ9*'s Profile Search for other posts by IQ9*
dontbuytitan04
Posted: Dec 23 2004 at 11:47pm | IP Logged Quote dontbuytitan04
Hendo, the vibration I got from my front end at idle is when the aux fan went on and then it vibrates. The fan is loose in the bottom holder. the dealer said that was a factory mount and found nothing wrong. Yeah right!
Danny
Back to Top View dontbuytitan04's Profile Search for other posts by dontbuytitan04 Visit dontbuytitan04's Homepage
Smokin Joe
Posted: Dec 26 2004 at 10:47am | IP Logged Quote Smokin Joe
Why not?
Oh, please spread this around about brake rotors.
http://www.stoptech.com/whitepapers/warped_rotors_myth.htm
Back to Top View Smokin Joe's Profile Search for other posts by Smokin Joe
