Subject Topic: Rear diff oil??? Post ReplyPost New Topic
browndude3649
Posted: Dec 20 2004 at 8:37pm | IP Logged Quote browndude3649
Just did my firtst oil change on my CC, And checked the diff oil. Color was like gray green!!!! Is this normal or special oil for break-in!? I think i'm gonna change it anyways,so Who Recommends What? i also heard that Nissan is gonig to put out a TSB that At first oil-change- do Diff oil Also! What Weight should I put in?
Back to Top View browndude3649's Profile Search for other posts by browndude3649
camino70
Posted: Dec 21 2004 at 11:21am | IP Logged Quote camino70
I just changed my oil as well and while I was under there I decided to check the diffs.  Both the front and rear were about 3/4 of a quart low!  I didn't take notice to the color though.  As for what to change with, I am not sure.  I am a fan of mobil one for oil changes, so I added mobile one gear oil.  As for changing, I would assume some limited slip additive may be needed, not sure though.
Ron
'04 Canteen LE 4X4 no packages, no mods, yet...
Back to Top View camino70's Profile Search for other posts by camino70
