Titan Towing / Hauling
 Nissan Titan Forums : Titan Towing / Hauling
Subject Topic: titan tow mode Post ReplyPost New Topic
titan711
Posted: Jan 01 2005 at 1:40pm | IP Logged Quote titan711
when using tow mode with a column shifter on manual , do you guys have to push tow mode first then push the manual shifter button? it wont let me turn on tow mode after i push manual shift mode.
i read on other forums where people were saying that they couldnt even use tow mode during manual shift mode but it works on my truck if i turn in on first then switch to manual shift mode
thanks
Back to Top View titan711's Profile Search for other posts by titan711
cybernathor
Posted: Feb 19 2005 at 12:18pm | IP Logged Quote cybernathor
titan711
I have the exact same behavior on mine (SE, 4X4, OFFROAD/BIG TOW, 04-2004). Figured that I can live with it, just put in tow-mode before shifting to D and then when I go into manual shifting the tow mode light stays on.
Back to Top View cybernathor's Profile Search for other posts by cybernathor
Mavryck
Posted: Mar 01 2005 at 9:34pm | IP Logged Quote Mavryck
My understanding is that TOW MODE changes the shift points (allows the engine to rev higher before it shifts) therefore if you are shifting manually TOW MODE doesn't apply (you shift at the rpm that you choose).
Mavryck
'04 Titan SE, King Cab, 4X4, Off Road, Big Tow
Back to Top View Mavryck's Profile Search for other posts by Mavryck
