optic1 Newbie
Online Status: Offline Posts: 26
Posted: Jan 10 2005 at 7:12pm | IP Logged
Sounds like many of you have the lamps installed. Keep the laughter down but did you have to take the whole headlight assembly out to get to the lamps. My arms certainly won't fit. Or do I need to commission some skinny chick?
Posted: Jan 12 2005 at 11:08am | IP Logged
You can access the headlight from behnd the bumper. You don't have to take apart the front end.
Posted: Jan 12 2005 at 3:36pm | IP Logged
Yes one of the 2, either the high or low beam can be reached from under the hood, the other is fairly easy to reach by removing one screw from under the plastic wheel well and sneaking up from behind...GL
azoolander Newbie
Online Status: Offline Posts: 1
Posted: Jan 14 2005 at 5:56pm | IP Logged
high beam is easy, it can be accessed thru engine compartment.
For low beam, turn wheel in, remove screws holding plastic wheel well and fold wheel well back You will see the bulb in there
optic1 Newbie
Posted: Jan 15 2005 at 12:43am | IP Logged
Thanks guys, very easy when you know where to look.
rapineda61 Groupie
Online Status: Offline Posts: 93
Posted: Jan 15 2005 at 1:22am | IP Logged
how much do you pay for the lihgt? where can i get the best deal. anyone thanks
04 le crew cab, z grill ,tinted, 22 wheels,sb tono tonneau cover,etc
optic1 Newbie
Posted: Jan 15 2005 at 10:30am | IP Logged
Just search "silverstar 9006 ST" on ebay their the low beams.
"silverstar 9005 ST" are the high beams. I got the pair for $23.00
Our local shucks auto sells them for $49.99 for the pair
Posted: Jan 17 2005 at 4:51pm | IP Logged
Thank you to those emebers that actually knew how to do it. I wish I could have quoted many of you-sorry I did not.
BuyDell Groupie
Online Status: Offline Posts: 82
Posted: Jan 17 2005 at 5:09pm | IP Logged
thepuffman wrote:
Yes one of the 2, either the high or low beam can be reached from under the hood, the other is fairly easy to reach by removing one screw from under the plastic wheel well and sneaking up from behind...GL |
Hey Puffman,
Do you really think they made a difference ?? Also, do they look "whiteish" or "Blueish" ?
__________________ 04 LE CC, 4x4, Pearl White, Big Tow Package
18in Wheels
Posted: Jan 17 2005 at 5:56pm | IP Logged
Not blue ..After getting used to the blue tinted ones I got off of Ebay the SS's looked a little yellow...until I compared them to the regular Halogen. The SilverStars are definately white IMHO. If you like that slight bluish tint then I would get something else...if you just want a more natural white light Id recommend the SS's
