Subject Topic: popping in four wheel drive Post ReplyPost New Topic
physics
Posted: Jan 17 2005 at 10:51am | IP Logged Quote physics
Has anyone else that is used to driving 4x4 noticed an excessive
amount of wheel skid when in four wheel drive on dry pavement?
When I pulled into my parking lot this morning I had to turn on 4x4 for
a second to get through some ice. The parking lot itself is clear and I
noticed a LOT of popping and wheel skidding when I was making turns.
Turn 4x4 off and it goes away. Happens in 4 hi and lo.
I know 4 wheel drives do this and have driven many, just seemed
excessive and don't remember it on this truck before.
Thanks,
Chris
2004 King Cab SE Sedona
Back to Top View physics's Profile Search for other posts by physics
Mitch
Posted: Jan 17 2005 at 1:18pm | IP Logged Quote Mitch
Sounds normal to me. My buddies Chevy does the same thing, you can't really even drive his on dry pavement in 4WD.
Mitch
Back to Top View Mitch's Profile Search for other posts by Mitch Visit Mitch's Homepage
IQ9*
Posted: Jan 17 2005 at 4:50pm | IP Logged Quote IQ9*
Have you checked the front diff to see if it has any fluid? Nissan is have quite a bit of trouble with near-empty and empty diffs front and rear.
04 LE CC, 4x4, Pearl White, debadged, Venture Clear Bra
Back to Top View IQ9*'s Profile Search for other posts by IQ9*
thepuffman
Posted: Jan 17 2005 at 5:39pm | IP Logged Quote thepuffman
Excessive? ..I dunno, but I think this is the reason they tell you not to use 4WD on dry pavement.
SE Kingcab Smoke Gray, Big Tow, K&N filter, Silverstar lamps, Peragon hard tonneau, (Sirius SR, 350W Alpine amp, Polk spkrs, 2 RF 8" subs, custom box)
Back to Top View thepuffman's Profile Search for other posts by thepuffman
IQ9*
Posted: Jan 19 2005 at 12:20pm | IP Logged Quote IQ9*
Puffman's got a point.
CactusJackSlade
Posted: Jan 19 2005 at 4:56pm | IP Logged Quote CactusJackSlade
Sounds normal to me too... mine does the same thing. I am pretty sure it has to do with the front end geometery somewhat as well - inside wheel turning smaller radius than outer wheel while under a load etc... makes you wonder how Subaru's and others work so well ???
CJS
http://www.racemtbikes.com
Back to Top View CactusJackSlade's Profile Search for other posts by CactusJackSlade Visit CactusJackSlade's Homepage
jimb
Posted: Jan 19 2005 at 5:17pm | IP Logged Quote jimb
I thought that too when I read this yesterday, or whenever. DON'T DRIVE IT ON DRY PAVEMENT IN 4X4. Not good! Bad!! - Jim
Back to Top View jimb's Profile Search for other posts by jimb
thepuffman
Posted: Jan 19 2005 at 8:16pm | IP Logged Quote thepuffman
  I imagine they have a full-time 4WD...the Titan isnt.
IQ9*
Posted: Jan 20 2005 at 3:03pm | IP Logged Quote IQ9*
The QX56 is  full time. We should all convert over to their drive train
besserheimerpha
U.S. - Iowa
Posted: Jan 20 2005 at 3:46pm | IP Logged Quote besserheimerpha
I've heard of this on other truck forums--problem is that there is no diff. between front and rear.  When you turn, the front cuts a larger path that the rear, so the front wheels try turning slightly faster than the rears.  In 4WD, the front and rear axles are locked together and are forced to spin at the same speed.  The front wheels get all bound up and "hop."  Cars like the Subaru with AWD, and some SUV's I think, now do have the extra diff, eliminating the wheel hop.  And yes this does cause a lot of stress in the drivetrain and is why they say to not use it on dry pavement.  It happens on Ford, Dodge and Chevy, particularly the HD models that have solid front axles.  I think I remember reading somewhere that it is less severe on vehicles with independent front suspension.
Back to Top View besserheimerpha's Profile Search for other posts by besserheimerpha
