Subject Topic: Auto window up switch problem... STILL! Post ReplyPost New Topic
CactusJackSlade
Posted: Jan 18 2005 at 11:43pm | IP Logged Quote CactusJackSlade
I know this problem has been addressed on other threads, but I just wanted to see if anyone has actually had there auto up FIXED?
I'm talking about when you pull the window switch for full auto up and it goes  "Clunk-Clunk" - up about an inch then back down, then refuses to go up at all. I have had mine "overload" so much that you have to literally wait 15-20 seconds for it to "re-set" before the window will do ANYTHING!
I was very fortunate that when I dropped it off at the dealers today (for the second time - same issue) The service tech actually got it to mess up right before his eyes, therefor the problem was "verified".
This is the second time around on this and it will be interesting to see what they will do - if anything.
Anyone else STILL living with this problem?
CJS
CJS
http://www.racemtbikes.com
Back to Top View CactusJackSlade's Profile Search for other posts by CactusJackSlade Visit CactusJackSlade's Homepage
Mitch
Posted: Jan 19 2005 at 10:03am | IP Logged Quote Mitch
I had my reg and motor replaced and it worked for about a month then it started it again. On Dec 30th they replaced the switch and the problem stopped and the switch works much better now.
Mitch
Back to Top View Mitch's Profile Search for other posts by Mitch Visit Mitch's Homepage
CactusJackSlade
Posted: Jan 19 2005 at 4:52pm | IP Logged Quote CactusJackSlade
Well, I just returned from the dealer. I started to pull out of the shop and decided to test the window.
On my first try the window did the SAME THING as before: Up about a half inch then clunk back down. Try to get it to come up and it "locks up" and will not come up until you let go of the button and wait 10-15 seconds. BUMMER!
They said tha they replaced the switches, but obviously that did not work. SO... another day in the shop
CJS
CJS
thaimonkee
U.S. - Maryland
Posted: Jan 20 2005 at 1:43pm | IP Logged Quote thaimonkee
sometime wheni go to a drive thru to order food i roll the window down auto down. then when i drive away the window doesnt go up when i push it up. i have to mess around with for about a minute and then it goes up. its like there a loose connection or something. anyone else have this problem?
Back to Top View thaimonkee's Profile Search for other posts by thaimonkee
kaymonster
Posted: Jan 20 2005 at 4:40pm | IP Logged Quote kaymonster
this happens to me once in a while. after two or three tries it usually works though
Back to Top View kaymonster's Profile Search for other posts by kaymonster
dontbuytitan04
Posted: Jan 20 2005 at 11:28pm | IP Logged Quote dontbuytitan04
I had my switches replace at Mossy in San diego and It fixed all the roll up problems.
Danny
Back to Top View dontbuytitan04's Profile Search for other posts by dontbuytitan04 Visit dontbuytitan04's Homepage
Todd TCE
Posted: Jan 22 2005 at 8:53am | IP Logged Quote Todd TCE
This just might prove one of the things we learn to live with. Mine switch was replaced and yea, it still does it. If you are worried don't go down all the way in the rain and it still comes back up.
Sharing many the same BS problems you have too.
Back to Top View Todd TCE's Profile Search for other posts by Todd TCE Visit Todd TCE's Homepage
BuyDell
U.S. - New Jersey
Posted: Jan 22 2005 at 10:13am | IP Logged Quote BuyDell
 If it help anyone....I have found that if I hold the window UP button for more then a second or two, the windows then go up by them selfs. At least for me it made a BIG difference   !!!
04 LE CC, 4x4, Pearl White, Big Tow Package
18in Wheels
Back to Top View BuyDell's Profile Search for other posts by BuyDell
ClashoftheTITAN
http://www.lubedealer.com/ealubrication/
Posted: Jan 23 2005 at 1:58pm | IP Logged Quote ClashoftheTITAN
I think I found your problem..  Do you, by chance, have the in channel vent visors installed on the windows?  It is the additional space  required for these that causes the window issue...
Hope this helps.
TITAN 4x2 LE 2005
XM Nation
Amsoil Distributor
www.environmentalassociates.biz
Back to Top View ClashoftheTITAN's Profile Search for other posts by ClashoftheTITAN Visit ClashoftheTITAN's Homepage
thepuffman
Posted: Jan 24 2005 at 1:59pm | IP Logged Quote thepuffman
Hope this helps.
Those can cause problems, but I have them and they work fine...there was a time or 2 when they were new that the windows did not want to go up, but no problems since then.
SE Kingcab Smoke Gray, Big Tow, K&N filter, Silverstar lamps, Peragon hard tonneau, (Sirius SR, 350W Alpine amp, Polk spkrs, 2 RF 8" subs, custom box)
Back to Top View thepuffman's Profile Search for other posts by thepuffman
Page of 3 Next >>
