| Posted: Jan 22 2005 at 5:22am | IP Logged
You changed the rear diff fluid at 4,700? How come?
Also, just curious - did you drop the cover back there - or did you suck out the fluid through the hole. Also, haven't read up on this anywhere - but since you did it you probably know - is a bottle of "anti-slip" stuff required when you re-fill back there? I know a bottle of that is a little pricey and didn't know if Nissan requires it - like Dodge does - or not?
Any info on changing aft-diff. fluid appreciated....
