Subject Topic: low beams waaay too bright? Post ReplyPost New Topic
denver_dan
Posted: Jan 23 2005 at 8:28pm | IP Logged Quote denver_dan
Hello,
Am I the only one with this issue?  My lowbeams are so bright that I constantly am getting flashed and severely irritating the drivers in front of me.  My Titan has 9K miles and is 6months old.... the amount of light seems ridiculous for low beams.    Any recommendations?
Back to Top View denver_dan's Profile Search for other posts by denver_dan
Bill B
U.S. - Virginia
Posted: Jan 23 2005 at 9:08pm | IP Logged Quote Bill B
I had same problem...to see what other drivers are seeing just step out in front of your truck and crouch down to about the level an oncoming driver would be and see for yourself.....took it back to dealer and they said they were correct...so I adjusted them dowm myself....under hood, behind and at top of headlight is a torx 15 screw adjuster...I just parked about 50' from a building on level ground and adjusted them to about 4' off ground at that point....drivers side a little lower...this is just about right now...if you want to get technical go to one of these sites....not a link, you will have to copy and paste the address...hope this helps
http://faq.auto.light.tripod.com/hl-aiming.htm
http://home.att.net/~borrani/articles/tech/aimhigh2.htm
2004 White SE King Cab,K&N Air Filter,Line X Bed Liner,XM Radio,LED Lights between tailgate and bumper
Back to Top View Bill B's Profile Search for other posts by Bill B
denver_dan
Posted: Jan 23 2005 at 11:20pm | IP Logged Quote denver_dan
Got 'em adjusted!  piece of cake.   Thanks a ton Bill!
Bill B
U.S. - Virginia
Posted: Jan 26 2005 at 6:27pm | IP Logged Quote Bill B
you're welcome Dan
