Subject Topic: Ignition switch problems Post ReplyPost New Topic
royjratc
U.S. - Ohio
Posted: Jan 24 2005 at 3:46pm | IP Logged Quote royjratc
Went out to start that trustworthy truck this a.m. - Key would not turn! Not quite sure why - Thought maybe steering wheel was locked - Seen that on other cars/trucks. But no amount of playing with the steering wheel while trying jiggle the key helps.
Of course, I can't even get the truck into nuetral now, as the shift lever won't move unless the key is turned.
Has this happened to anyone else? Any ideas before I have this towed?
Roy-NY
Back to Top View royjratc's Profile Search for other posts by royjratc
thepuffman
Posted: Jan 24 2005 at 4:25pm | IP Logged Quote thepuffman
I know the key has a chip in it, if something was wrong with it I assume it would still turn but not crank...not sure tho...I'd call the dealership first.
SE Kingcab Smoke Gray, Big Tow, K&N filter, Silverstar lamps, Peragon hard tonneau, (Sirius SR, 350W Alpine amp, Polk spkrs, 2 RF 8" subs, custom box)
Back to Top View thepuffman's Profile Search for other posts by thepuffman
royjratc
U.S. - Ohio
Posted: Jan 24 2005 at 4:38pm | IP Logged Quote royjratc
Thanks - I thought about the chip too. And my wife did put a snow encrusted key in yesterday!
Roy-NY
jimb
Posted: Jan 24 2005 at 5:04pm | IP Logged Quote jimb
A 'snow encrusted' key, and you're in New York? What is it -- about -3 up there in the morning? This may sound completely obvious, but do you think sub-freezing temps and water-turned-ice in the ignition as a result of a snow encrusted key might be a factor?
Back to Top View jimb's Profile Search for other posts by jimb
jimb
Posted: Jan 24 2005 at 5:10pm | IP Logged Quote jimb
It'll crank just fine/beatifully with the wrong chip - right until you drain the battery. It won't start, however.
ZeroInteruppt
Posted: Mar 24 2005 at 5:49pm | IP Logged Quote ZeroInteruppt
Not sure if this is the same problem that you've been having but I have had two other nissan trucks and they ALL have the same problem.  Every once in a while for no reason at all the key's just don't work. Usually i just have to play with it for a while.   I have a 1991 Nissan SE 4x4, a 96 Nissan 4x2 (which I have since given away), and now of course my 05 Nissan 4x4.
Back to Top View ZeroInteruppt's Profile Search for other posts by ZeroInteruppt
royjratc
U.S. - Ohio
Posted: Mar 25 2005 at 7:28am | IP Logged Quote royjratc
Actually - Jimb was right - Snow melted into the ignition & froze - Took 2 days before the temperature got warm enough & then it started right up
Roy-NY
watsor1
Posted: Mar 29 2005 at 5:57pm | IP Logged Quote watsor1
Actually you can get it into neutral without the key working.  At the forward end of the console (I ass u me you have a floor shift) there is a little circular cover.  Pry this puppy off and there is a release mechanism that will let you get  the shifter out of park.  The procedure is in the owner's manual, but I can't remember where.
Rick
2004 White LE King Cab, 2WD, Tow Package, Decals On The Hood (V8s off the fenders), tailgate debadged. Silverstar Ultra.
In Texas, the state goes on forever, and the party never ends
Back to Top View watsor1's Profile Search for other posts by watsor1
Kevante
U.S. - Arizona
Posted: Mar 29 2005 at 7:22pm | IP Logged Quote Kevante
rick, That is a good idea. good thinking.
CC LE Galaxy Black
Kevin
Back to Top View Kevante's Profile Search for other posts by Kevante
