| Posted: May 11 2004 at 10:50pm | IP Logged
For your King Cab, buy the Crew Cab Vent Visors from VentaShade, use the fronts and throw the rears away.  The fronts look great, the rears don't and don't serve any useful purpose, since the rear windows don't open anyway.
When installing the fronts, position the flange between the surface of the door and the rubber gasket, not between the mirror and the gasket.  There will be a slight gap where the rubber is separated from the surface of the door.  Just use a little clear silicon rubber to seal that and the installation is done and waterproof.
Also, the Nissan Bug deflector fits great, much better than a couple of non-nissan units that I looked at.  ($70.00 at local dealer.)
  __________________ TitanWild
