Subject Topic: Leaning a bit to the left... Post ReplyPost New Topic
Marthafocker
U.S. - Florida
Posted: Feb 13 2005 at 5:28pm | IP Logged Quote Marthafocker
On level ground looking at the truck from the back there is a noticable tilt to the left.  My Truck is a 04' crew cab LE 4x4 with about 9000 miles.  Had this same problem with my wife's Yukon but was able to solve with a torsion bar adjustment.  I checked and did not see any torsion bars underneath. Also I checked tire pressure and thats not the culprit, with equal pressure all the way around.. Is this something the dealer should fix under the warranty???
P.s.  We are not big people and have not stressed the springs.....
Its the wallet that says "Bad Marthafocker on it"
Back to Top View Marthafocker's Profile Search for other posts by Marthafocker
Marthafocker
U.S. - Florida
Posted: Feb 15 2005 at 8:55pm | IP Logged Quote Marthafocker
Come on fella's...All I hear is cricketts....Was hoping to hear something back from one of you Nissan Gurus...Does anyone else have this leaning problem and if so did you get it corrected???
'04 off road
Posted: Feb 15 2005 at 10:47pm | IP Logged Quote '04 off road
i can honestly say mine looks perfectly level on both sides i would take it in for the heck of it and ask the dealer whats up
Back to Top View '04 off road's Profile Search for other posts by '04 off road
pied_piper
U.S. - Oklahoma
Posted: Feb 16 2005 at 8:47am | IP Logged Quote pied_piper
No leaning here. All I can recommend is take it to the dealer and show them.
Back to Top View pied_piper's Profile Search for other posts by pied_piper
sohard4u
U.S. - Pennsylvania
Posted: Feb 20 2005 at 4:46pm | IP Logged Quote sohard4u
Maybe your Titan was made in Pisa, Italy which would explain the lean to one side.
It could be a problem with one of the shocks or leaf springs.
If worse comes to worst, just put a counterweight on the other side to level it.
Back to Top View sohard4u's Profile Search for other posts by sohard4u
