| Posted: Feb 18 2005 at 7:03pm | IP Logged
Just bought a CC Titan and found what I think is the perfect cover...
it is a RETRAX cover...Hard cover, retractable into a canister that mounts at the front of the cab, but is on sealed bearings, and requires no springs or moving parts in that canister. Is about as watertight as a cover can be except for the solid hinged type. It locks, works super-smooth. In the neighborhood of $800.00, but it's worth it to get it out of the way in 2 seconds when you need to use the bed for big stuff. It can also be latched and locked in any position. Very secure and useful.
I think you can find it at www.rolltopcover.com
Bought mine from www.web4jnj.com for the best price and the owner is great! From Iowa same as me, so I thought he deserved the chance and did not dissapoint.
The cover works fine with the trac in place, just can't use the track at the front of the bed 'cause that's where the canister is mounted.
