TSB - Technical Bulletins
 Nissan Titan Forums : Problems / Technical : TSB - Technical Bulletins
Subject Topic: water leaks Post ReplyPost New Topic
Burkey
U.S. - Florida
Posted: Apr 08 2005 at 12:32pm | IP Logged Quote Burkey
I have a 2004 Titan SE Crew Cab:
Has anyone had a problem with water getting into the cab front drivers side at the mat under the feet of the driver?
Burkey
Back to Top View Burkey's Profile Search for other posts by Burkey
bigbear05
U.S. - Alabama
Posted: Apr 08 2005 at 2:42pm | IP Logged Quote bigbear05
You need to check you AC drain hose. I think this was a problem that some other people have encountered, and if I'm not mistaken that was the problem. Either it was clogged or was kinked. Take it to the dealer and tell them that the AC hose is leaking and let them look at it. If I can find a simaler post regarding this problem, I'll post a link.
Back to Top View bigbear05's Profile Search for other posts by bigbear05
bigbear05
U.S. - Alabama
Posted: Apr 08 2005 at 2:48pm | IP Logged Quote bigbear05
http://www.titantalk.com/forums/showthread.php?t=12420&highl ight=passenger+water
Maybe this will help you. It is from another forum I visit frequently. I noticed that you said it was you driver's side. This post was refering to the passenger side. Have you check it too see if it is wet? Anyways maybe this will be of some help.
Pax River Titan
U.S. - Maryland
Posted: Dec 04 2005 at 7:54pm | IP Logged Quote Pax River Titan
I've had a problem with LOTS of water in my crew cab - completly soaks the rear carpet. I just figured out it's coming from the SLIDING REAR WINDOW. Turns out there is a TSB on it too! Nissan actually puts a drain tube in the insdie window track and out through the rubber weather seal. What a goofy fix.   What I want to know is how's the water getting inside to begin with?
I'm taking this in to get fixed.
Anyone else had this problem and repair?
Dave
Back to Top View Pax River Titan's Profile Search for other posts by Pax River Titan
harley99titan
Posted: Aug 06 2007 at 5:40pm | IP Logged Quote harley99titan
i just had a problem with my rear window i thought it was the window and they found at the dealer that there are 2 black lines on the top of my truck in the black lines are some sort of vents one of my vents was cracked and leaking into the rear of the driver side truck same question here how was that getting into my truck???? they said they glued it to fix it...i don't see that lasting to long...never realized it was leaking until my brother was sitting in the back seat and we had a down pour the back window was dripping really bad...we will see...
Back to Top View harley99titan's Profile Search for other posts by harley99titan
