thaimonkee Groupie
Online Status: Offline Posts: 88
| Posted: May 12 2005 at 5:37pm | IP Logged
I have a 2004 titan with big tow package. the rear wheel has a huge gap. i know its a truck but still i want to lower the rear end alittle to even out with the front. what is recomended for this?. any help would be great,.
Mavryck Groupie
Online Status: Offline Posts: 92
| Posted: May 12 2005 at 7:29pm | IP Logged
thaimonkee wrote:
| I have a 2004 titan with big tow package. |
Tow something heavy
__________________ Mavryck
'04 Titan SE, King Cab, 4X4, Off Road, Big Tow
jun3462 Newbie
Online Status: Offline Posts: 10
| Posted: May 13 2005 at 5:04am | IP Logged
same here thaimonkee. i just installed 22s with nittos 285/45 and the wheelwell is more exposed. heard you can get drop shackles and will drop about 2 inches on the back. i will research more and let you know.
thaimonkee Groupie
| Posted: May 13 2005 at 6:00am | IP Logged
thanks. im pretty sure somewhere sells like a 2 inch drop for the rear somewhere.
there another guy,m95roadster, he said to de-arch the leaf springs. but i have no idea what that means
ensclark Newbie
Online Status: Offline Posts: 28
| Posted: May 13 2005 at 6:56am | IP Logged
If you put on the helper springs on the front. It will work as a traction bar and drop it some where between .5 and 1 inch. I'm sure you are all looking for more than that but it may help. It's amazing what a inch looks likes
__________________ 4LE,CC,BT,OR,Fullyloaded,Bullbar,NitrousEnterpriseslevel/lif t kit,ARE bedcover,centerline17x8 rims,
m95roadster Newbie
Online Status: Offline Posts: 22
| Posted: May 13 2005 at 1:57pm | IP Logged
De-arching the spring is basically reshaping it to any height you
choose. A suspension shop can do this for you. The spring rate remains
the same as stock.
__________________ 2005 SE CC Smoke
Flowmaster American Thunder Exhaust - click here
m95roadster Newbie
| Posted: May 13 2005 at 2:00pm | IP Logged
there another guy,m95roadster, he said to de-arch the leaf springs. but i have no idea what that means |
There is no room under the bed for a 2" shackle drop. To even get to 1 1/2" you would need to grind the bed somewhat.
thaimonkee Groupie
| Posted: May 13 2005 at 3:33pm | IP Logged
i called streetbeat customs and they have 2x4 inch drop but thats alitle too much for what im looking for. i just want the rear to be even with the fronmt. and there kit cost 800 shipped which is too much for me right now. i ask most shops around here to see if they do that dearching and no ones does it. not yet at least.
m95 roadster. how many inch drop or whatever they call it did you do when you dearched your leaf's?
m95roadster Newbie
| Posted: May 13 2005 at 3:56pm | IP Logged
yet at least.
m95 roadster. how many inch drop or whatever they call it did you do when you dearched your leaf's? |
Call 4x4 shops. They'll know. I had mine dropped 2 1/2" rear and the front is 1".
I had the kit you were talking about and it sucked bad. Worst ride
ever! The drop was more like 4 1/2" rear and 1" front. The back sat a
lot lower than the front.
Kevante Senior Member
Online Status: Offline Posts: 255
| Posted: May 13 2005 at 9:10pm | IP Logged
I want to level the rear also but not sure how to do it without cutting or huge dollars.
__________________ CC LE Galaxy Black
Kevin
