| Posted: Aug 13 2007 at 1:31pm | IP Logged
I bought some PIAA 4000 lights. They have a set of fogs, a set of
driving plus two small marker lights you attach to the turn signal or
parking light circuit. The wires are quite small and the wiring
diagram shows you attach the wires directly to either the turn signal
wires or parking lights.
Where is the easiest spot to access this circuit? I looked at the fuse
panel, but I don't see one for either circuit where I could use an
"Add-a-Circuit". Should I just try to tap into the signal wires under
the hood on each side? If so, where is the easiest place to try and
access these wires?
Thanks for any feedback.
