Posted: Jun 29 2004 at 1:01pm | IP Logged
Just last weekend I went took the truck up the mountain thru some slopes and curves. Then the truck started vibrating while braking with fully loaded truck with 6 full-size people and about 400 lbs. of camping gears. It also did not feel as if there was not enough clamping power on those rotors and took longer distance and time to stop.
I believe the rotors may have warped as I read a few others at other sites having the warped brake rotors. Will take it back to the dealer for this vibration while braking. I heard somewhere that Nissan is planning on a possible recall for the brake rotor change. Does anyone have any information on the brake warpage and may have encountered similar braking problem? I now have 6000 miles on the truck.
Thanks for feedback.
__________________ Mytruck04
